causes:woodworking [2020/01/23 10:21] |
causes:woodworking [2020/01/31 23:31] |
- | The Woodworking Cause is lead by Joshua Hogendorn, and receives quite a lot of help from Craig Hudson-Taylor. We're aiming to provide a shop that can cater for construction needs through to fine cabinetry and carving. | + | The Woodworking Cause is lead by Joshua Hogendorn, and receives quite a lot of help from Ian Roving. We're aiming to provide a shop that can cater for construction needs through to fine cabinetry and carving. |
- | We currently hang out every **Thursday from 6pm onwards**, come by and have a chat, build some things! | + | |
You can [[causes:woodworking:operatingpolicy|view our Operating Policy here on the Wiki]]. | You can [[causes:woodworking:operatingpolicy|view our Operating Policy here on the Wiki]]. | ||
Line 45: | Line 43: | ||
* 16mm MDF (Bunnings) | * 16mm MDF (Bunnings) | ||
* 12mm AA Marine Ply (https://www.marineplywoodqld.com.au/) | * 12mm AA Marine Ply (https://www.marineplywoodqld.com.au/) | ||
- causes/woodworking
