causes:woodworking [2020/01/18 14:44] |
- | You can [[causes:woodworking:operatingpolicy|view our Operating Policy here on the Wiki]]. | + | |
Line 22: | Line 23: | ||
- | * [[/tools/woodshop/tablesaws|PS-12 Sliding Table Saw]] | ||
- | * [[tools:woodshop:bandsaw|N4400 Bandsaw]] | ||
- | * [[tools:woodshop:smallbandsaw|H&F Mini Bandsaw]] | ||
- | * [[tools:woodshop:thicknesserplaner|A3-31 Jointer/Planer Thicknesser]] | ||
- | * [[tools:woodshop:dropsaw|Hitachi Drop/Mitre Saw]] | ||
- | * Drill Press | ||
- | * Belt and Disk Sander | ||
- | * Spindle Sander | ||
- | * Drum Sander | ||
- | * [[tools:woodshop:discsander|Disc Sander]] | ||
- | * [[tools:woodshop:scrollsaw|Scrollsaw]] | ||
- | * Lathe | ||
- | * Dust Extraction | ||
- | === Power Tools === | ||
- | === Hand Tools === | ||
- | TBA |
- causes/woodworking.1579322661
