Both sides previous revision
howto:closeup [2018/11/22 19:01] |
howto:closeup [2018/11/22 22:04] |
- If you're the last on site, you will need to make sure to lock the gate(s) behind you. | - If you're the last on site, you will need to make sure to lock the gate(s) behind you. |
- If you have parked out the front, because the front area was open make sure to close the front gate and inform Port Security | - If you have parked out the front, because the front area was open make sure to close the front gate and inform Port Security |
- If there is nobody in the quad, including Team Arrow and Mens Shed double check the hardstand area and close and lock the gate. The code for the gate is provided on slack by slackbot. | - If there is nobody in the quad, including Team Arrow and Mens Shed double check the hardstand area and close and lock the gate. The code for the gate is provided on discord by the bot or the last page of your new members guide. |
