howto:closeup [2018/11/22 19:00] |
howto:closeup [2023/02/10 21:39] (current) zacmarcus |
- | ====== HOWTO Close up the space ====== | + | ====== Close up the space ====== |
So, it's been a long day of hacking and you're the last one in the space or in a cause area. It's finally time to go home. But wait! Aren't you forgetting something? | So, it's been a long day of hacking and you're the last one in the space or in a cause area. It's finally time to go home. But wait! Aren't you forgetting something? | ||
Line 24: | Line 24: | ||
- Make sure the toilet door (at the end of the hallway) is closed. | - Make sure the toilet door (at the end of the hallway) is closed. | ||
- Check windows in the greenroom, hipster lounge, kitchen and classroom. | - Check windows in the greenroom, hipster lounge, kitchen and classroom. | ||
- | - Make sure that both the Quad door closes and lock properly. | + | - Make sure that both the Quad door closes and lock properly |
+ | - Ensure all gas bottles have been closed. | ||
- Make sure the Mill and Lathes are turned off at the wall. | - Make sure the Mill and Lathes are turned off at the wall. | ||
+ | - Turn off all power and lights. | ||
- Close the big roller door and lock the padlock. | - Close the big roller door and lock the padlock. | ||
- Return the Metal Shop key to Members Storage. | - Return the Metal Shop key to Members Storage. | ||
Line 35: | Line 36: | ||
- Turn off all the lights, the switches are just beside the door (don't forget the orange one behind the doorframe. | - Turn off all the lights, the switches are just beside the door (don't forget the orange one behind the doorframe. | ||
- Close the roller door, making sure it closes properly. | - Close the roller door, making sure it closes properly. | ||
+ | - Put gas bottles away and lock the padlock | ||
+ | - Return the Gas key to Members Storage. | ||
===== The Site ===== | ===== The Site ===== | ||
- If you're the last on site, you will need to make sure to lock the gate(s) behind you. | - If you're the last on site, you will need to make sure to lock the gate(s) behind you. | ||
- If you have parked out the front, because the front area was open make sure to close the front gate and inform Port Security | - If you have parked out the front, because the front area was open make sure to close the front gate and inform Port Security | ||
- | - If there is nobody in the quad, including Team Arrow and Mens Shed double check the hardstand area and close and lock the gate. The code for the gate is provided on slack by slackbot. | + | - If there is nobody in the quad, including Team Arrow and Mens Shed double check the hardstand area and close and lock the gate. The code for the gate is provided on discord by the bot or the last page of your new members guide. |
- howto/closeup.1542877257
