howto:closeup [2018/11/22 22:04] |
howto:closeup [2023/02/10 21:39] (current) zacmarcus |
- | ====== HOWTO Close up the space ====== | + | ====== Close up the space ====== |
So, it's been a long day of hacking and you're the last one in the space or in a cause area. It's finally time to go home. But wait! Aren't you forgetting something? | So, it's been a long day of hacking and you're the last one in the space or in a cause area. It's finally time to go home. But wait! Aren't you forgetting something? | ||
Line 26: | Line 26: | ||
- Make sure that both the Quad door closes and lock properly | - Make sure that both the Quad door closes and lock properly | ||
+ | - Ensure all gas bottles have been closed. | ||
- Make sure the Mill and Lathes are turned off at the wall. | - Make sure the Mill and Lathes are turned off at the wall. | ||
+ | - Turn off all power and lights. | ||
- Close the big roller door and lock the padlock. | - Close the big roller door and lock the padlock. | ||
- Return the Metal Shop key to Members Storage. | - Return the Metal Shop key to Members Storage. | ||
Line 34: | Line 36: | ||
- Turn off all the lights, the switches are just beside the door (don't forget the orange one behind the doorframe. | - Turn off all the lights, the switches are just beside the door (don't forget the orange one behind the doorframe. | ||
- Close the roller door, making sure it closes properly. | - Close the roller door, making sure it closes properly. | ||
+ | - Put gas bottles away and lock the padlock | ||
+ | - Return the Gas key to Members Storage. | ||
===== The Site ===== | ===== The Site ===== |
- howto/closeup.1542888254
