howto:lights [2020/02/06 20:16] |
howto:lights [2020/09/30 03:25] (current) blufires Not a boneyard any more |
+ | ===== Find a Light Switch ===== | ||
+ | Most light switches are in sensible places, but some are non-obvious. | ||
+ | === Road-Side Spotlights === | ||
+ | Outside wall at the corner of the Team Arrow building closest to our front driveway. On the road side of the corner, around chest height. | ||
+ | === Interior Car Park Spotlights === | ||
+ | On the back of the Men's Shed building against the throughfare of our driveway, around half-way along the building. You may need a stick or may need to climb over the Men's Shed's stuff to reach this switch. | ||
+ | === Quad === | ||
+ | 5 switches under a clear weatherproof cover, next to the right-most Team Arrow door. | ||
+ | === Machine shop === | ||
+ | Single switch about 1m in from the door, on the right when first walking in. | ||
+ | === Woodshop === | ||
+ | Three switches, two of which are hard to find. | ||
+ | - The obvious one is next to the sliding door with the rest of the switches/power-points, on the right when first walking in. | ||
+ | - Near the first one, just inside the door jamb of the sliding door is another switch, facing towards the boneyard. | ||
+ | - On the right side of the window into the machine shop is an old power-point with a red light - this powers the tools on the back wall and also the overhead light. | ||
+ | === Automotive cause / Blacksmithing cause storage === | ||
+ | Light switches on the left side of the blue container that's closest to the woodshop. | ||
+ | === Kitchen === | ||
+ | Next to the PPE/First-aid cabinet. | ||
+ | === Green Room === | ||
+ | Above the AED (defibrillator) cabinet between the whiteboard and the can crusher. | ||
+ | === Hipster Lounge & Lobby === | ||
+ | To the left of the lounge when facing it, on the other side of the door to the store room/hot water room/switchboard room. | ||
+ | === Hallway to the Toilets === | ||
+ | Left of the door to Members Storage. | ||
+ | === Classroom === | ||
+ | One switch to the left of each door into the room, inside the room. | ||
+ | === Flashing Neon "OPEN" Sign === | ||
+ | In the closet room in the Classroom, around ankle height on the left near the door. Technically not a light, but included here anyway. | ||
+ | === Member Storage === | ||
+ | There isn't one! The light goes on automatically whenever the door is open. | ||
+ | === Mens Toilets === | ||
+ | There isn't one! There's a motion sensor to the left of the door when you walk in, next to the Urinal. | ||
+ | === Womens Toilets === | ||
+ | Two switches in the atrium just outside the Women's toilets. One is for the atrium light, the other is for the toilets. |
