howto:upmini [2020/04/11 12:01] 127.0.0.1 external edit |
howto:upmini [2020/10/17 13:45] hsbnewiki |
- Take a look at the printer filament spool and ensure there's enough filament on the roll for your print. | - Take a look at the printer filament spool and ensure there's enough filament on the roll for your print. | ||
- A good rule of thumb is for every square CM of your print there should be 15CM on the spool. | - A good rule of thumb is for every square CM of your print there should be 15CM on the spool. | ||
- Initialise Printer | - Initialise Printer | ||
- | - On the attached PC, run the 'UP 2.18' software. <WRAP center round info 60%>The Up Studio software isn't working with this printer anymore.</WRAP> | + | - On the attached PC, run the 'UP 2.18' software. <callout type="info" icon="true">Make sure you have opened Up 2.18, the 'Up Studio' software currently does not work with this printer.</callout> |
- On the Main Menu click 3D Print and then Initialize. | - On the Main Menu click 3D Print and then Initialize. | ||
- Insert Bed | - Insert Bed | ||
Line 16: | Line 17: | ||
- The printhead will start to heat up, within 5 minutes the printhead temperature will reach 260 degrees then the printer will buzz and the print head starts to extrude. | - The printhead will start to heat up, within 5 minutes the printhead temperature will reach 260 degrees then the printer will buzz and the print head starts to extrude. | ||
- Watch the printer push the filament out, making sure it's not coming out sideways. If it is, report it to the #digifab chat. | - Watch the printer push the filament out, making sure it's not coming out sideways. If it is, report it to the #digifab chat. | ||
- | - When it completes it will beep again, pull the filament out and it should be a nice smooth coil of filament. <WRAP center round important 60%>Do not reach up towards the nozzle, reach down towards the bed.</WRAP><WRAP center round info 60%>If it is bubbly or textured report this to #digifab chat.</WRAP><WRAP center round info 60%>If the filament doesn't come out at all, report this to #digifab chat.</WRAP> | + | - When it completes it will beep again, pull the filament out and it should be a nice smooth coil of filament. <alert type="danger" icon="fa fa-warning">Do not reach up towards the nozzle, reach down towards the bed.</alert><callout type="info" icon="true">If the filament is bubbly or textured or doesn't come out at all, report this to #digifab chat.</callout> |
- Set up Print | - Set up Print | ||
- Clean off Bed | - Clean off Bed | ||
- | Changing Filament | + | ====== Changing Filament ====== |
+ | - Click New Spool. | ||
- howto/upmini
- by hsbnewiki
