tools:digitalfabrication:3dprinters:home [2020/04/11 12:01] 127.0.0.1 external edit |
tools:digitalfabrication:3dprinters:home [2023/04/26 05:17] (current) bwilkins [3D Printers] |
+ | ==== PETG ==== | ||
+ | ==== ABS ==== | ||
+ | ==== ASA ==== | ||
- | [[https://github.com/HSBNE/RepRap-Configurations|Configuration files for our 3D printers]] | ||
==== Cron Job ==== | ==== Cron Job ==== |
- by bwilkins
