tools:home [2020/08/31 09:40] jabelone [Areas] |
- | A tool page template can be found[[tools:template| here]]. | + | ===== Add New Tool ===== |
- | ==== Areas ==== | + | {{NEWPAGE>tools}} |
- | === Automotive === | + | \\ 1) Login using your HSBNE Wiki account (contact @infrastructure on discord if you have any problems). |
- | === Blacksmithing === | ||
- | === Craft Punk === | + | \\ \\ |
- | <nspages tools:craftpunk -subns -exclude:home -usePictures -h1 -textNS="" -textPages="" -subns -pagesInNs -naturalOrder> | + | ===== Craft Punk ===== |
+ | Overseen by the [[causes/metalworking|Metal Shop Team]]. <nspages tools:metalshop -exclude:home -exclude:yaglaser -exclude:wip: -exclude:handtools: -usePictures -h1 -textNS="" -textPages="" -subns -pagesInNs -naturalOrder> | ||
- | === Digital Fabrication === | ||
- | Overseen by the [[causes/digitalfabrication|Digital Fabrication Cause]]. | ||
- | <nspages tools:digitalfabrication -r -exclude:home -usePictures -h1 -textNS="" -textPages="" -subns -pagesInNs -naturalOrder> | ||
- | === Electronics Bench === | + | ===== Infrastructure ===== |
- | === Metal Shop === | + | Overseen by the [[causes/infrastructure|Infrastructure Cause]]. <nspages tools:infrastructure -exclude:home -usePictures -h1 -textNS="" -textPages="" -subns -pagesInNs -naturalOrder> |
- | <nspages tools:metalshop -exclude:home -usePictures -h1 -textNS="" -textPages="" -subns -pagesInNs -naturalOrder> | + | |
- | === Wood Shop === | + | \\ \\ |
- | <nspages tools:woodshop -exclude:home -usePictures -h1 -textNS="" -textPages="" -subns -pagesInNs -naturalOrder> | + |
