tools:metalshop:linisher [2021/10/06 20:42] ryan6338 [Usage] |
tools:metalshop:linisher [2023/06/28 08:51] capella_ben [Documents] |
Line 3: | Line 3: | ||
Line 32: | Line 24: | ||
Book an induction on Eventbrite.\\ | Book an induction on Eventbrite.\\ | ||
- | [[https://www.eventbrite.com/d/australia--south-brisbane/drill-press-linishers-vertical-bandsaw-induction-(hsbne-members-only)/?page=1]] | + | [[https://www.eventbrite.com/cc/metalshop-inductions-804979]] |
Line 51: | Line 43: | ||
Line 85: | Line 77: | ||
Line 130: | Line 118: | ||
Line 141: | Line 138: | ||
- tools/metalshop/linisher
