causes:electronics [2019/06/07 15:08] |
causes:electronics [2020/10/28 00:40] hsbnewiki |
- | <WRAP center round box 60%> | ||
- | **Location:** The Electronics bench, taking up the right hand wall of the Green room, opposite where the TV is mounted. | + | {{ :causes:electronics.jpg?direct&600|}} |
+ | <panel> | ||
+ | **Location:** The Electronics bench, taking up the right hand wall of the Green room, opposite where the TV is mounted.\\ | ||
+ | **Cause Leader:** [[user:BadBiki|Lucas]]\\ | ||
+ | **Objective:** To provide functional and professional electrical equipment for the development, debugging and assembly of electrical projects ranging in complexity and quality. From entry-level evaluation boards and Raspberry Pi's all the way up to PCB assembly and Reflow Soldering.\\ | ||
+ | **Communications:** [[https://forum.hsbne.org/c/cause-effect/electronics|Forums]] and #electronics in [[https://discord.gg/avtkH5t|Discord Chat]].\\ | ||
+ | **Operating Policy:** [[causes:electronics:operatingpolicy|Policy]] | ||
- | **Cause Leader:** Brendan (nog3) Halliday - Previously Blair Calderara | + | </panel> |
- | **Objective:** To provide an accessible electronics work-space that allows advanced electronic design to be conducted at HSBNE. | + | ===== Cause Area Expectations ===== |
+ | * Always clean the work area when you leave. Flag and/or clean up any mess left by others. | ||
+ | * Only "Extra Low Voltage" projects are allowed to be worked on, unless you are a licensed QLD electrician. | ||
+ | * Hot (heat) or Live (Powered) tools or projects must not be left unattended. | ||
+ | * Live projects should be adequatly protected from accidental bumping, proding, spills. | ||
+ | * Communicate with others if you have sensitive equipment exposed on the bench. | ||
- | **Members:** See [[https://portal.hsbne.org/cause/list/|Current List]] | + | ===== Cause Owned Equipment ===== |
- | **Communications:** [[https://forum.hsbne.org/c/cause-effect/electronics|Forums]] and #electronics in [[https://discord.gg/avtkH5t|Discord Chat]]. | ||
- | ===== Cause Area Expectations ===== | ||
- | * Please leave the area as clean or cleaner than you found it. | ||
- | * Please make sure to put money in the donation tin for consumables. | ||
- | * Please don’t leave things running on the power supplies unattended. | ||
- | * Please don’t leave irons or other tools on when you’re not immediately using them. | ||
- | * Please return tools to their homes. | ||
+ | * JST, Molex, AMP | ||
- | * Introduction to logic gates\\ | + | {{tag>electronics}} |
- | * Making a PCB\\ | + | |
- causes/electronics
