causes:electronics [2020/11/01 21:05] jabelone [Electronics Cause] |
causes:electronics [2020/11/01 21:09] jabelone |
- | {{ :causes:electronics.jpg?direct&600|}} | ||
- | **Location:** The Electronics bench, taking up the right hand wall of the Green room, opposite where the TV is mounted.\\ | + | {{ : causes: electronics.jpg?direct&400|The electronics bench}} |
- | **Cause Leader:** [[user:BadBiki|Lucas]]\\ | + | <WRAP> |
- | **Objective:** To provide functional and professional electrical equipment for the development, debugging and assembly of electrical projects ranging in complexity and quality. From entry-level evaluation boards and Raspberry Pi's all the way up to PCB assembly and Reflow Soldering.\\ | + | |**Location** | The Electronics bench, taking up the right hand wall of the Green room, opposite where the TV is mounted. | |
- | **Members:** See [[https://portal.hsbne.org/cause/list/|Portal Cause Membership]]\\ | + | |**Cause Leader** | [[user:BadBiki|Lucas]] | |
- | **Communications:** [[https://forum.hsbne.org/c/cause-effect/electronics| Forum Category]] \\ [[https://discord.gg/t3TPRq2Ew5|Discord Chat]] \\ | + | |**Objective** | To provide functional and professional electrical equipment for the development, debugging and assembly of electrical projects ranging in complexity and quality. From entry-level evaluation boards and Raspberry Pi's all the way up to PCB assembly and Reflow Soldering. | |
- | **Operating Policy:** [[causes:electronics:operatingpolicy|Policy]] | + | |**Members** | [[https://portal.hsbne.org/cause/list/|Portal Cause Membership]] | |
+ | |**Communications** | [[https://forum.hsbne.org/c/cause-effect/electronics|Forum Category]] \\ [[https://discord.gg/XpMznccTEt|Discord Chat]] \\ [[https://trello.com/invite/b/EkFs17hM/cd4b100222e897de0db90a984a032509/electronics|Trello Task Tracking]] | | ||
</panel> | </panel> | ||
- causes/electronics
