causes:metalworking [2020/11/01 21:24] jabelone |
causes:metalworking [2022/09/30 09:11] capella_ben |
- | ====== Metalworking Cause ====== | + | ====== Metalworking Team ====== |
- | {{ :causes:metalshop.jpg?direct&600|}} | + | |
- | **Location:** The Metal Shop is located in the big shed, on the left hand side when facing towards the road from inside the quad. | + | {{ : causes: metalshop.jpg?direct&400|The metal shop area}} |
+ | | **Location** | The Metal Shop is located in the big shed, on the left hand side when facing towards the road from inside the quad. | | ||
+ | | **Cause Leader** | Ryan Marple (@Ryan M) | | ||
+ | | **Objective** | To always maintain a work space environment with a high standard of safety and a respect for other members of HSBNE using the metal shop. This can be achieved through the cooperation and adhering to the policies, procedures and processes of the Metal Shop. | | ||
+ | | **Current Goals** | Restructure shop to be more usable. | | ||
+ | | **Members** | [[https://portal.hsbne.org/cause/list/|Portal Cause Membership]] | | ||
+ | | **Communications** | [[https://forum.hsbne.org/c/cause-effect/metalworking|Forum Category]] \\ [[https://chat.hsbne.org/|Discord Chat]] \\ [[https://trello.com/invite/b/rkCyfwbd/26dc2c066dd645153560a41bbde70b88/metalshop|Trello Task Tracking]] | | ||
+ | | **Operating Policy** | [[causes:metalworking:operatingpolicy|Policy]] | | ||
- | **Cause Leader:** Craig Rea | + | * Plan your work piece and work steps. Check here or on Discord that the tools you need are in the shop.\\ |
- | **Objective:** To always maintain a work space environment with a high standard of safety and a respect for other members of HSBNE using the metal shop. This can be achieved through the cooperation and adhering to the policies, procedures and processes of the Metal Shop.\\ | + | * Get inducted and double check work steps for safe practices.\\ |
- | **Current goals:** | + | * Leave the area as clean or cleaner than you found it.\\ |
- | * Restructure shop to be more usable | + | |
- | * Run classes | + | |
- | **Members:** See [[https://portal.hsbne.org/group/list/|Metalshop members]]\\ | + | * Only use tools in the way they are intended to be used.\\ |
- | **Communications:** [[https://forum.hsbne.org/c/cause-effect/metalworking|Forums]] and [[https://discord.gg/avtkH5t|Discord Chat]]. Look for #cause-metalworking\\ | + | * Ask for help or guidance when you need it.\\ |
- | **Operating Policy:** [[causes:metalworking:operatingpolicy|Policy]] | + | * Respect that some members may not want to break their focus to talk or answer questions. The exception to this rule is in the case of dangerous or disrespectful tool use and emergencies.\\ |
- | </panel> | + | |
- | <panel> | ||
- | {{ : causes: metalshop.jpg?direct&400|The metal shop area}} | ||
- | <WRAP> | ||
- | |**Location** | The Metal Shop is located in the big shed, on the left hand side when facing towards the road from inside the quad. | | ||
- | |**Cause Leader** | Craig (@reatek) | | ||
- | |**Objective** | To always maintain a work space environment with a high standard of safety and a respect for other members of HSBNE using the metal shop. This can be achieved through the cooperation and adhering to the policies, procedures and processes of the Metal Shop. | | ||
- | |**Current Goals** | Restructure shop to be more usable, and run classes. | | ||
- | |**Members** | [[https://portal.hsbne.org/cause/list/|Portal Cause Membership]] | | ||
- | |**Communications** | [[https://forum.hsbne.org/c/cause-effect/metalworking |Forum Category]] \\ [[https://discord.gg/86ZSJQkm|Discord Chat]] \\ [[https://trello.com/invite/b/rkCyfwbd/26dc2c066dd645153560a41bbde70b88/metalshop|Trello Task Tracking]] | | ||
- | |**Operating Policy** | [[causes:metalworking:operatingpolicy|Policy]] | | ||
</panel> | </panel> |
- causes/metalworking
