tools:woodshop:thicknesserplaner [2021/01/03 22:02] ale Implementation of the tool template |
tools:woodshop:thicknesserplaner [2022/12/18 15:06] ale |
- | **PLACEHOLDER** | ||
Line 35: | Line 28: | ||
Line 40: | Line 34: | ||
+ | ==== Induction ==== | ||
- | PLACEHOLDER: Please make a simple diagram using [[draw.io|draw.io]] to show induction process. Delete this line. | + | This machine's induction, as some others in the woodshop, is organized through a [[https://forum.hsbne.org/search?q=inductions%20between%20%23cause-effect%3Awoodworking%20order%3Alatest|forum post]]. In the following link, you will find more information about it. [[teams:woodworking:getting_around#what_machines_require_induction|Getting around - Inductions]] |
- | {{:tools:woodshop:tablesaw-inductionflow.png?nolink|}} | + | |
- | At the moment we are inducting members on this machine by doing an hour and a half long in-person induction on the shop. To get inducted you need to follow these steps: | + | |
- | - Look for a date that's suitable for you on this link and sign on. https://www.eventbrite.com.au/e/planerthicknesser-hammer-a3-31-induction-tickets-134515805395 | + | |
- | - Assist to the induction on the chosen date | + | |
Line 82: | Line 69: | ||
Line 120: | Line 107: | ||
- | | PLACEHOLDER Image, 100 width | PLACEHOLDER Category of consumable | **PLACEHOLDER Consumable Name** \\ PLACEHOLDER Consumable description and usage | PLACEHOLDER Description of where the consumable is stored | PLACEHOLDER Link to where it can be bought | | + | | | General | Carbide inserts (13.8x13.8.x2.5 R150). | On the cutter head plastic box, inside the dewalt cart tool (pantorouter) | They can be bought for a cheaper price than felder in amazon. https://www.amazon.com.au/Hammer-Felder-Silent-Spiral-Cutter/dp/B06XKJP3PT | |
+ | ==== 28/03/2021 ==== | ||
+ | I've installed a new set of inserts on the cutter head. To keep tracking next time we will rotate these inserts clockwise. The photo indicates how they were installed this time. Ale More. | ||
+ | {{ :tools:woodshop:inset_changed_on_28.03.2021.jpg?direct&200 |}} | ||
+ | ==== 27/06/2021 ==== | ||
- | ===== Maintenance ===== | + | {{ :tools:woodshop:insert_changed_on_20210627134804.jpg?direct&200 |}} |
- | ^ Interval ^ Task ^ | + | ==== 16/04/2022 ==== |
- | | PLACEHOLDER Pick one: Daily/Weekly/Monthly/Quarterly/Biannual/Annual | PLACEHOLDER Description of maintenance task and any relevant parameters | | + | I've rotated the inserts. To keep tracking next time we will rotate these inserts clockwise. The photo indicates how they were installed this time. Ale More. |
