tools:woodshop:thicknesserplaner [2021/03/29 19:43] ale [Table] |
tools:woodshop:thicknesserplaner [2022/12/18 15:06] ale |
- | **PLACEHOLDER** | ||
Line 28: | Line 21: | ||
Line 43: | Line 36: | ||
- | In summary: | + | |
Line 92: | Line 69: | ||
Line 130: | Line 107: | ||
- | | PLACEHOLDER Image, 100 width | General | Carbide inserts (13.8x13.8.x2.5 R150). | On the cutter head plastic box, inside the dewalt cart tool (pantorouter) | They can be bought for a cheaper price than felder in amazon. https://www.amazon.com.au/Hammer-Felder-Silent-Spiral-Cutter/dp/B06XKJP3PT | | + | | | General | Carbide inserts (13.8x13.8.x2.5 R150). | On the cutter head plastic box, inside the dewalt cart tool (pantorouter) | They can be bought for a cheaper price than felder in amazon. https://www.amazon.com.au/Hammer-Felder-Silent-Spiral-Cutter/dp/B06XKJP3PT | |
Line 145: | Line 122: | ||
{{ :tools:woodshop:inset_changed_on_28.03.2021.jpg?direct&200 |}} | {{ :tools:woodshop:inset_changed_on_28.03.2021.jpg?direct&200 |}} | ||
+ | ==== 27/06/2021 ==== | ||
+ | ==== 16/04/2022 ==== | ||
