Next revision
tools:woodshop:thicknesserplaner [2022/04/25 13:55]
ale [27/06/2021]
tools:woodshop:thicknesserplaner [2022/12/18 15:10]
ale [16/04/2022]
Line 1: Line 1:
-<WRAP 50% center round important>​
-**PLACEHOLDER**
-**This page is under construction using the tool template.**
-I copied the tool template and pasted it before what we already have written about this machine in order to not loose information but to start using and filling the tool template. Ale Moré
-</​WRAP>​
 <WRAP column third> <WRAP column third>
 {{:​tools:​woodshop:​1948.png?​nolink&​400|}} {{:​tools:​woodshop:​1948.png?​nolink&​400|}}
Line 28: Line 21:
 ===== Current Status ===== ===== Current Status =====
-<​WRAP ​warning ​half round> +<​WRAP ​safety ​half round>
-=== Usable ​===+=== Working ​===
-The thicknesser ​is not feeding the material. We will have to adjust the pressure rollers tension.+Machine ​is working as expected.
 </​WRAP>​ </​WRAP>​
Line 43: Line 36:
 ==== Induction ==== ==== Induction ====
-In order to get inducted on this machine, you need to go to the following Eventbrite event and book a place for yourself on one of the available dates. +This machine'​s ​induction, ​as some others in the woodshop, is organized ​through a [[https://​forum.hsbne.org/​search?​q=inductions%20between%20%23cause-effect%3Awoodworking%20order%3Alatest|forum ​post]]. In the following link, you will find more information ​about it. [[teams:​woodworking:​getting_around#​what_machines_require_induction|Getting around ​Inductions]]
-{{https://​www.eventbrite.com.au/​e/​planerthicknesser-hammer-a3-31-induction-tickets-134515805395#​|Planer/​Thicknesser inductions}} +
-After thatyou just need to come that day and take the induction. Please pay attention to the description of the event because there'​s a couple of things that you need to comply with. Most importantlybe on time and bring your own mandatory PPE. +
-The cause has a commitment to giving at least one induction per week on one of the machines that require induction. +
-The way we organize all of this is by having fortnightly polls on the forum. By doing this we can check the actual demand and deliver a solution. +
-When we create dates they will be announced ​through ​discord (woodchop channel) and the messages will be pinned. +
-In summary: +
-  - Check this link to see if you can book an induction: {{https://​www.eventbrite.com.au/​e/​planerthicknesser-hammer-a3-31-induction-tickets-134515805395#​|Planer/​Thicknesser inductions}}. +
-  - Check the forum to see if there'​s ​poll open to organize the following inductions and vote accordingly.[[https://​forum.hsbne.org/​c/cause-effect/​woodworking/​11|Woodworking ​forum]] +
-  - Talk to the cause leader ​about it or start a conversation on discord. +
-  ​Check the helpdesk channel on discord. +
 ==== Guidelines ==== ==== Guidelines ====
Line 154: Line 131:
 {{ :​tools:​woodshop:​img20220418105656.jpg?​200 |}} {{ :​tools:​woodshop:​img20220418105656.jpg?​200 |}}
 +==== 18/12/2022 ====
 + ​I’ve replace the inserts with a whole new set. To keep tracking next time we will rotate these inserts clockwise. The photo indicates how they were installed this time. Ale More.
 +{{:​tools:​woodshop:​bb2b77da-09b5-4649-b14c-2deabb603817.jpeg?​400|}}
 ===== RACI ===== ===== RACI =====
  • tools/woodshop/thicknesserplaner
  • Last modified: 18 months ago
