howto:communicate [2018/07/19 22:12] |
howto:communicate [2020/04/11 12:01] 127.0.0.1 external edit |
+ | ====== Contact other Members ====== | ||
To contact another member, Simply create or login with a Discord account with the following link, | To contact another member, Simply create or login with a Discord account with the following link, | ||
[[https://discord.gg/SHQ5W7t|Discord Invite]] | [[https://discord.gg/SHQ5W7t|Discord Invite]] | ||
Select the persons name in the list of members on the right of the Discord page, | Select the persons name in the list of members on the right of the Discord page, | ||
+ | and select message, if you would like the message to be public select Mention | ||
If you don't want to sign up to Discord you can also use the Forums | If you don't want to sign up to Discord you can also use the Forums | ||
[[https://forum.hsbne.org/|HSBNE Forums]] | [[https://forum.hsbne.org/|HSBNE Forums]] |
- howto/communicate
