policies:storage [2020/08/15 14:15] devians removed |
— (current) | ||
- | ====== Storage Policy ====== | ||
- | There are several forms of storage for members at HSBNE. The group [[https://hsbne.org/admin/meeting/20130115.html|provides members with crated temporary project storage in the lockable storage area]], and it also allows members to ‘park’ projects for specified periods of time. There are also External Storage options available. | ||
- | ===== Members Storage ===== | ||
- | * Members are issued a single 55L black crate on starting a membership. | ||
- | * Crates, once issued, are the property of their owners, and as such are not rented or leased from HSBNE. | ||
- | * To ensure availability of Members Storage spots, Members should only take up one spot in members storage. | ||
- | * Members who do not use members storage for a month should take their project home instead of storing it at HSBNE. | ||
- | * Containers remaining after a month of inactivity from when you last swiped in to members storage or the space in general may be sent to long term storage to clear space for others to use. | ||
- | ===== Parking Projects ===== | ||
- | Parking projects is part of the HSBNE Ticket system. | ||
- | ===== External Storage ===== | ||
- | HSBNE has a limited amount of space to provide storage for larger in progress projects. | ||
- | Any item stored externally must have a green parking permit on it clearly marking what it is/who owns it/when it was put there and how to contact the owner. | ||
- | For usable external storage there are two areas defined. Temporary Large Storage and Hardstand Storage. Please note that storage outside of these areas is not specifically allowed and will need to be moved due to lease obligations. | ||
- | ==== Temporary Large Project Storage: ==== | ||
- | If you are working on a large project that needs to be stored on site to be worked on, you may store it in Temporary Large Project Storage. | ||
- | Items stored in Temporary Large Project Storage: | ||
- | * must have a green parking permit on it clearly marking what it is/who owns it/when it was put there. | ||
- | * may be stored there for a period of up to a month. To store it for longer than a month there must be a vote at a members meeting approving any time period above thea month of storage. | ||
- | * must be visibly actively worked on, as this is temporary storage space for projects in progress. The best way to demonstrate it is actively worked on is through a Build Log on the forum or by blog posts. | ||
- | ==== Hardstand Project Storage: ==== | ||
- | This area consists of bays that are slightly larger than a standard shipping pallet in size. | ||
- | Items stored in Hardstand Project Storage: | ||
- | * must have a green parking permit on it clearly marking what it is/who owns it/when it was put there. may be stored there for a period of up to a month, with the standard green ticket requirements for any period longer than a month. | ||
- | * may only take up one slot per member, to allow for equal opportunity of use. | ||
