causes:blacksmithing [2020/10/28 00:41] hsbnewiki Image to the right. |
causes:blacksmithing [2020/11/01 21:03] jabelone |
- | {{ :causes:forge.jpeg?direct&600}} | ||
- | **Objective:** The main purpose of the blacksmithing area is to provide a self maintained and intuitive area to practise the arts of blacksmithing, metal forging and sand casting.\\ | + | |
- | **Members:** See [[https://portal.hsbne.org/cause/list/|Current List]]\\ | + | |
- | **Communications:** [[https://forum.hsbne.org/c/cause-effect/blacksmithing|Forums]] and #forge in [[https://discord.gg/avtkH5t|Discord Chat]].\\ | + | |
- | **Operating Policy:** [[causes:blacksmithing:operatingpolicy|Policy]] | + | |
+ | |**Location** | The Forge is in the Hardstand, immediately to your right after the first container. | | ||
+ | |**Cause Leader** | To be updated | | ||
+ | |**Objective** | The main purpose of the blacksmithing area is to provide a self maintained and intuitive area to practise the arts of blacksmithing, metal forging and sand casting. | | ||
+ | |**Communications** | [[https://forum.hsbne.org/c/cause-effect/blacksmithing|Forum Category]] \\ [[https://discord.gg/mfURB4|Discord Chat]] \\ [[https://trello.com/invite/b/tTIJx7YS/c528d5acd464469b4903db1a5881b4d3/forge|Trello Task Tracking]] | | ||
</panel> | </panel> | ||
- causes/blacksmithing
zacmarcus
