causes:blacksmithing [2020/04/14 14:44] nogthree |
- | Leader: Alan Webb | + | {{ :causes:forge.jpeg?nolink|}} |
- | ---- | + | <panel> |
+ | **Location:** The Forge is in the Hardstand, immediately to your right after the first container..\\ | ||
+ | **Cause Leader:** \\ | ||
+ | **Operating Policy:** [[causes:blacksmithing:operatingpolicy|Policy]] | ||
- | The main purpose of the blacksmithing area is to provide a self maintained and intuitive area to practise the art of blacksmithing, metal forging and sand casting. | + | </panel> |
- | To reach this goal we have to complete the following items: | + | ===== Cause Owned Equipment ===== |
- | - | + | ===== Member Owned Equipment on Loan ===== |
- | To maintain a clean, safe and organised smithy, there will be some small tasks that members will have to complete: | ||
- | After each use, the user much: | + | ===== Ongoing Budgets ===== |
- | - Ensure that all tools are put away in their designated areas after use. | + | ===== Current Goals ===== |
- | Monthly takes: | + | |
+ | - stocktake of fuel | ||
+ | - stocktake of tools | ||
- causes/blacksmithing
