Next revision | Previous revision Next revision Both sides next revision | ||
causes:digitalfabrication [2020/04/11 12:01] 127.0.0.1 external edit |
causes:digitalfabrication [2020/10/28 00:22] jabelone |
- | <WRAP center round box 60%> | + | ====== Digifab Cause ====== |
+ | {{ : causes:digifab.jpg?direct&600|The digifab room}} | ||
+ | |**Location** | Digifab is located in the left most room when you walk into the green room and turn towards Eat St. | | ||
+ | |**Cause Team**. | Brendan Halliday (@nog3), Aaron Bycroft (@crofty) and Michael King (@doc) | | ||
====== Digital Fabrication Cause ====== | ====== Digital Fabrication Cause ====== | ||
+ | {{ :causes:digifab.jpg?nolink|}} | ||
+ | <panel type="default" title=""> | ||
**Location:** The Digital Fabrication room is the room on the left at the end of the Green Room farthest from the driveway. | **Location:** The Digital Fabrication room is the room on the left at the end of the Green Room farthest from the driveway. | ||
Line 12: | Line 26: | ||
**Communications:** [[https://forum.hsbne.org/c/cause-effect/digital-fabrication|Forums]] and #cause-digifab in [[https://discord.gg/avtkH5t|Discord Chat]]. | **Communications:** [[https://forum.hsbne.org/c/cause-effect/digital-fabrication|Forums]] and #cause-digifab in [[https://discord.gg/avtkH5t|Discord Chat]]. | ||
- | </WRAP> | + | **Operating Policy:** [[causes:digitalfabrication:operatingpolicy|Policy]] |
+ | </panel> | ||
===== Cause Area Rules ===== | ===== Cause Area Rules ===== | ||
Line 32: | Line 48: | ||
- causes/digitalfabrication
