causes:digitalfabrication [2020/04/12 17:01] nogthree |
- | <panel type="default" title="Digital Fabrication Cause"> | + | ====== Digifab Cause ====== |
- | **Location:** The Digital Fabrication room is the room on the left at the end of the Green Room farthest from the driveway. | + | {{ : causes:digifab.jpg?direct&600|The digifab room}} |
- | **Objective:** Digital Fabrication's goals are to provide, maintain, and run classes for equipment in the principles of digital fabrication and related fabrication services | + | </WRAP> |
- | **Members:** See [[https://portal.hsbne.org/cause/list/|Current List]] | + | |
- | **Recommended Suppliers**: [[https://wiki.hsbne.org/causes/digitalfabrication/suppliers|See here]]. | + | |
- | **Communications:** [[https://forum.hsbne.org/c/cause-effect/digital-fabrication|Forums]] and #cause-digifab in [[https://discord.gg/avtkH5t|Discord Chat]]. | + | |
- | </panel> | + | |
===== Cause Area Rules ===== | ===== Cause Area Rules ===== | ||
Line 31: | Line 31: | ||
- causes/digitalfabrication
