causes:digitalfabrication [2020/04/14 13:59] nogthree |
causes:digitalfabrication [2020/08/26 18:51] jabelone [Tools requiring Induction] |
Line 13: | Line 13: | ||
**Communications:** [[https://forum.hsbne.org/c/cause-effect/digital-fabrication|Forums]] and #cause-digifab in [[https://discord.gg/avtkH5t|Discord Chat]]. | **Communications:** [[https://forum.hsbne.org/c/cause-effect/digital-fabrication|Forums]] and #cause-digifab in [[https://discord.gg/avtkH5t|Discord Chat]]. | ||
+ | **Operating Policy:** [[causes:digitalfabrication:operatingpolicy|Policy]] | ||
</panel> | </panel> | ||
Line 33: | Line 35: | ||
- causes/digitalfabrication
