causes:digitalfabrication [2020/04/14 14:44] nogthree |
causes:digitalfabrication [2020/10/28 00:22] jabelone |
+ | ====== Digifab Cause ====== | ||
+ | {{ : causes:digifab.jpg?direct&600|The digifab room}} | ||
+ | |**Location** | Digifab is located in the left most room when you walk into the green room and turn towards Eat St. | | ||
+ | |**Cause Team**. | Brendan Halliday (@nog3), Aaron Bycroft (@crofty) and Michael King (@doc) | | ||
====== Digital Fabrication Cause ====== | ====== Digital Fabrication Cause ====== | ||
{{ :causes:digifab.jpg?nolink|}} | {{ :causes:digifab.jpg?nolink|}} | ||
Line 35: | Line 48: | ||
- causes/digitalfabrication
