causes:digitalfabrication [2020/04/12 17:01] nogthree |
causes:digitalfabrication [2020/04/14 14:44] nogthree |
- | <panel type="default" title="Digital Fabrication Cause"> | + | ====== Digital Fabrication Cause ====== |
+ | {{ :causes:digifab.jpg?nolink|}} | ||
+ | <panel type="default" title=""> | ||
**Location:** The Digital Fabrication room is the room on the left at the end of the Green Room farthest from the driveway. | **Location:** The Digital Fabrication room is the room on the left at the end of the Green Room farthest from the driveway. | ||
Line 11: | Line 13: | ||
**Communications:** [[https://forum.hsbne.org/c/cause-effect/digital-fabrication|Forums]] and #cause-digifab in [[https://discord.gg/avtkH5t|Discord Chat]]. | **Communications:** [[https://forum.hsbne.org/c/cause-effect/digital-fabrication|Forums]] and #cause-digifab in [[https://discord.gg/avtkH5t|Discord Chat]]. | ||
+ | **Operating Policy:** [[causes:digitalfabrication:operatingpolicy|Policy]] | ||
</panel> | </panel> | ||
- causes/digitalfabrication
