causes:electronics [2019/06/08 17:05] |
causes:electronics [2020/11/01 21:05] jabelone [Electronics Cause] |
+ | {{ :causes:electronics.jpg?direct&600|}} | ||
+ | <panel> | ||
**Location:** The Electronics bench, taking up the right hand wall of the Green room, opposite where the TV is mounted.\\ | **Location:** The Electronics bench, taking up the right hand wall of the Green room, opposite where the TV is mounted.\\ | ||
- | **Cause Leader:** Brendan (nog3) Halliday\\ | + | **Cause Leader:** [[user:BadBiki|Lucas]]\\ |
- | **Objective:** To provide an accessible electronics work-space that allows advanced electronic design to be conducted at HSBNE.\\ | + | **Objective:** To provide functional and professional electrical equipment for the development, debugging and assembly of electrical projects ranging in complexity and quality. From entry-level evaluation boards and Raspberry Pi's all the way up to PCB assembly and Reflow Soldering.\\ |
- | **Members:** See [[https://portal.hsbne.org/cause/list/|Current List]]\\ | + | **Members:** See [[https://portal.hsbne.org/cause/list/|Portal Cause Membership]]\\ |
- | **Communications:** [[https://forum.hsbne.org/c/cause-effect/electronics|Forums]] and #electronics in [[https://discord.gg/avtkH5t|Discord Chat]].\\ | + | **Communications:** [[https://forum.hsbne.org/c/cause-effect/electronics| Forum Category]] \\ [[https://discord.gg/t3TPRq2Ew5|Discord Chat]] \\ |
+ | **Operating Policy:** [[causes:electronics:operatingpolicy|Policy]] | ||
+ | </panel> | ||
+ | * JST, Molex, AMP | ||
- | * Introduction to logic gates\\ | + | {{tag>electronics}} |
- | * Making a PCB\\ | + | |
- causes/electronics
