causes:electronics [2017/06/26 09:55] |
causes:electronics [2021/12/31 15:47] devians update discord link |
- | <WRAP center round box 60%> | ||
- | **Location:** The Electronics bench, taking up the right hand wall of the greenroom, opposite where the TV is mounted. | + | <panel> |
+ | {{ : causes: electronics.jpg?direct&400|The electronics bench}} | ||
+ | |**Location** | The Electronics bench, taking up the right hand wall of the Green room, opposite where the TV is mounted. | | ||
+ | |**Cause Leader** | [[user:BadBiki|Lucas]] | | ||
+ | |**Objective** | To provide functional and professional electrical equipment for the development, debugging and assembly of electrical projects ranging in complexity and quality. From entry-level evaluation boards and Raspberry Pi's all the way up to PCB assembly and Reflow Soldering. | | ||
+ | |**Communications** | [[https://forum.hsbne.org/c/cause-effect/electronics|Forum Category]] \\ [[https://chat.hsbne.org/|Discord Chat]] \\ [[https://trello.com/invite/b/EkFs17hM/cd4b100222e897de0db90a984a032509/electronics|Trello Task Tracking]] | | ||
+ | </panel> | ||
- | **Cause Leader:** Brendan (nog3) Halliday - Previously Blair Calderara | + | ===== Cause Area Expectations ===== |
+ | * Always clean the work area when you leave. Flag and/or clean up any mess left by others. | ||
+ | * Only "Extra Low Voltage" projects are allowed to be worked on, unless you are a licensed QLD electrician. | ||
+ | * Hot (heat) or Live (Powered) tools or projects must not be left unattended. | ||
+ | * Live projects should be adequatly protected from accidental bumping, proding, spills. | ||
+ | * Communicate with others if you have sensitive equipment exposed on the bench. | ||
- | **Objective:** To provide an accessible electronics work-space that allows advanced electronic design to be conducted at HSBNE. | + | ===== Cause Owned Equipment ===== |
- | **Members:** See [[http://porthack.hsbne.org/causes/causelist.php?causename=Electronics|Current List]] | ||
- | **Communications:** [[https://forum.hsbne.org/c/cause-effect/electronics|Forums]] and #electronics in Slack. | ||
- | ===== Cause Area Expectations ===== | ||
- | * Please leave the area as clean or cleaner than you found it. | ||
- | * Please make sure to put money in the donation tin for consumables. | ||
- | * Please don’t leave things running on the power supplies unattended. | ||
- | * Please don’t leave irons or other tools on when you’re not immediately using them. | ||
- | * Please return tools to their homes. | ||
+ | * JST, Molex, AMP | ||
- | * Introduction to logic gates\\ | + | {{tag>electronics}} |
- | * Making a PCB\\ | + | |
- causes/electronics
