causes:electronics [2020/04/12 17:06] nogthree |
causes:electronics [2020/04/14 15:06] nogthree |
+ | {{ :causes:electronics.jpg?nolink |}} | ||
**Location:** The Electronics bench, taking up the right hand wall of the Green room, opposite where the TV is mounted.\\ | **Location:** The Electronics bench, taking up the right hand wall of the Green room, opposite where the TV is mounted.\\ | ||
- | **Cause Leader:** Brendan (nog3) Halliday\\ | + | **Cause Leader:** [[user:nogthree|Brendan (nog3) Halliday]]\\ |
**Objective:** To provide an accessible electronics work-space that allows advanced electronic design to be conducted at HSBNE.\\ | **Objective:** To provide an accessible electronics work-space that allows advanced electronic design to be conducted at HSBNE.\\ | ||
**Members:** See [[https://portal.hsbne.org/cause/list/|Current List]]\\ | **Members:** See [[https://portal.hsbne.org/cause/list/|Current List]]\\ | ||
**Communications:** [[https://forum.hsbne.org/c/cause-effect/electronics|Forums]] and #electronics in [[https://discord.gg/avtkH5t|Discord Chat]].\\ | **Communications:** [[https://forum.hsbne.org/c/cause-effect/electronics|Forums]] and #electronics in [[https://discord.gg/avtkH5t|Discord Chat]].\\ | ||
+ | **Operating Policy:** [[causes:electronics:operatingpolicy|Policy]] | ||
</panel> | </panel> | ||
- causes/electronics
