causes:metalworking [2020/04/12 17:19] nogthree Moving operating policy into its own page. |
causes:metalworking [2021/12/31 15:38] devians updates discord link |
+ | **PLACEHOLDER** | ||
- | **Location:** The Metal Shop is located in the big shed, on the left hand side when facing the road. | + | {{ : causes: metalshop.jpg?direct&400|The metal shop area}} |
+ | |**Location** | The Metal Shop is located in the big shed, on the left hand side when facing towards the road from inside the quad. | | ||
+ | |**Cause Leader** | Craig (@reatek) | | ||
+ | |**Objective** | To always maintain a work space environment with a high standard of safety and a respect for other members of HSBNE using the metal shop. This can be achieved through the cooperation and adhering to the policies, procedures and processes of the Metal Shop. | | ||
+ | |**Current Goals** | Restructure shop to be more usable, and run classes. | | ||
+ | |**Communications** | [[https://forum.hsbne.org/c/cause-effect/metalworking |Forum Category]] \\ [[https://chat.hsbne.org/|Discord Chat]] \\ [[https://trello.com/invite/b/rkCyfwbd/26dc2c066dd645153560a41bbde70b88/metalshop|Trello Task Tracking]] | | ||
+ | |**Operating Policy** | [[causes:metalworking:operatingpolicy|Policy]] | | ||
- | **Cause Leader:** Craig Rea | + | * Leave the area as clean or cleaner than you found it.\\ |
- | **Objective:** To always maintain a work space environment with a high standard of safety and a respect for other members of HSBNE using the metal shop. This can be achieved through the cooperation and adhering to the policies, procedures and processes of the Metal Shop.\\ | + | * Only use tools in the way they are intended to be used.\\ |
- | **Current goals:** | + | * Ask for help or guidance when you need it.\\ |
- | * Restructure shop to be more usable | + | |
- | * Run classes | + | |
- | **Members:** See [[https://portal.hsbne.org/group/list/|Metalshop members]]\\ | + | * Respect that some members may not want to break their focus to talk or answer questions. The exception to this rule is in the case of dangerous or disrespectful tool use and emergencies.\\ |
- | **Communications:** [[https://forum.hsbne.org/c/cause-effect/metalworking|Forums]] and [[https://discord.gg/avtkH5t|Discord Chat]]. Look for #cause-metalworking\\ | + | ===== Metalworking Tools ===== |
- | **Operating Policy:** [[causes:metalworking:operatingpolicy|Policy]] | ||
</panel> | </panel> |
- causes/metalworking
