causes:metalworking [2020/12/14 08:14] geoffc |
causes:metalworking [2020/12/14 08:36] geoffc |
+ | **PLACEHOLDER** | ||
Line 12: | Line 20: | ||
- | * Only use tools you know how to use or have been inducted on.\\ | ||
+ | ===== Metalshop Tools ===== | ||
</panel> | </panel> |
- causes/metalworking
