causes:metalworking [2020/12/14 08:14] geoffc |
causes:metalworking [2020/12/14 09:19] geoffc |
+ | **PLACEHOLDER** | ||
Line 12: | Line 20: | ||
- | * Only use tools you know how to use or have been inducted on.\\ | ||
</panel> | </panel> | ||
+ | ===== Metalworking Cause page control register ===== | ||
+ | | 0000 | Creation of draft page | Page requires review and rework from cause members | 08/08/20 | JH | Approved | CR | 13/12/2020 | GeoffC created draft page | | ||
+ | | 0001 | Approval | Craig decides on any final rework | 1/2/2021 | GC | TBA | CR | TBA | TBA | |
- causes/metalworking
- Last modified: 24 months ago
