causes:metalworking [2020/12/14 08:33] geoffc |
causes:metalworking [2021/12/31 15:38] devians updates discord link |
Line 4: | Line 4: | ||
**This wiki is incomplete and still under construction.** | **This wiki is incomplete and still under construction.** | ||
- | This box will be deleted after approval of page by cause leader. | + | This box will be deleted after approval of this page by cause leader Craig. |
Line 16: | Line 16: | ||
|**Current Goals** | Restructure shop to be more usable, and run classes. | | |**Current Goals** | Restructure shop to be more usable, and run classes. | | ||
- | |**Communications** | [[https://forum.hsbne.org/c/cause-effect/metalworking |Forum Category]] \\ [[https://discord.gg/86ZSJQkm|Discord Chat]] \\ [[https://trello.com/invite/b/rkCyfwbd/26dc2c066dd645153560a41bbde70b88/metalshop|Trello Task Tracking]] | | + | |**Communications** | [[https://forum.hsbne.org/c/cause-effect/metalworking |Forum Category]] \\ [[https://chat.hsbne.org/|Discord Chat]] \\ [[https://trello.com/invite/b/rkCyfwbd/26dc2c066dd645153560a41bbde70b88/metalshop|Trello Task Tracking]] | |
|**Operating Policy** | [[causes:metalworking:operatingpolicy|Policy]] | | |**Operating Policy** | [[causes:metalworking:operatingpolicy|Policy]] | | ||
Line 32: | Line 34: | ||
</panel> | </panel> |
- causes/metalworking
