Both sides previous revision Previous revision | Next revision Both sides next revision | ||
causes:metalworking [2020/12/14 08:34] geoffc |
causes:metalworking [2020/12/14 08:36] geoffc |
Line 20: | Line 20: | ||
* Ask for help or guidance when you need it.\\ | * Ask for help or guidance when you need it.\\ |
- causes/metalworking
capella_ben
