causes:metalworking [2020/12/14 08:34] geoffc |
causes:metalworking [2020/12/14 09:19] geoffc |
Line 4: | Line 4: | ||
**This wiki is incomplete and still under construction.** | **This wiki is incomplete and still under construction.** | ||
- | This box will be deleted after approval of this page by cause leader. | + | This box will be deleted after approval of this page by cause leader Craig. |
Line 20: | Line 20: | ||
Line 32: | Line 34: | ||
</panel> | </panel> | ||
+ | ===== Metalworking Cause page control register ===== | ||
+ | | 0000 | Creation of draft page | Page requires review and rework from cause members | 08/08/20 | JH | Approved | CR | 13/12/2020 | GeoffC created draft page | | ||
+ | | 0001 | Approval | Craig decides on any final rework | 1/2/2021 | GC | TBA | CR | TBA | TBA | |
- causes/metalworking
