causes:woodworking [2020/02/06 20:16] |
- | The Woodworking Cause is lead by Joshua Hogendorn, and receives quite a lot of help from Ian Roving. We're aiming to provide a shop that can cater for construction needs through to fine cabinetry and carving. | + | |**Location** | The woodworking cause is located in the big shed, in the large room on the eastern side of the building. | |
- | You can [[causes:woodworking:operatingpolicy|view our Operating Policy here on the Wiki]]. | + | </WRAP> |
Line 20: | Line 23: | ||
- | You can [[causes:woodworking:suppliers|See a list of companies to buy supplies at here]]. | + | | Blades | Scrollsaw 125mm 14TPI | Scrollsaw | 10 | 5 | 10 | |
- | + | | Blades | [[https://www.bunnings.com.au/craftright-10-piece-jigsaw-blade-set_p6320394|Jigsaw variety pack]] | Jigsaws | 1 | 2 | 5 | | |
- | ==== Shop Contents ==== | + | | Carbide | 07.0.020 10pc Carbide 13.8x13.8x2.5 mm | A3-31 | 0 | 10 | 10 | |
- | * [[/tools/woodshop/tablesaws|PS-12 Sliding Table Saw]] | ||
- | * [[tools:woodshop:bandsaw|N4400 Bandsaw]] | ||
- | * [[tools:woodshop:smallbandsaw|H&F Mini Bandsaw]] | ||
- | * [[tools:woodshop:thicknesserplaner|A3-31 Jointer/Planer Thicknesser]] | ||
- | * [[tools:woodshop:dropsaw|Hitachi Drop/Mitre Saw]] | ||
- | * [[tools:woodshop:drillpress|Drill Press]] | ||
- | * [[tools:woodshop:beltanddisksander|Belt and Disk Sander]] | ||
- | * [[tools:woodshop:spindlesander|Spindle Sander]] | ||
- | * [[tools:woodshop:drumsander|Drum Sander]] | ||
- | * [[tools:woodshop:discsander|Disc Sander]] | ||
- | * [[tools:woodshop:scrollsaw|Scrollsaw]] | ||
- | * [[tools:woodshop:lathe|Lathe]] | ||
- | * [[tools:woodshop:dustextraction|Dust Extraction]] | ||
- | * [[tools:woodshop:handtools|Hand Tools]] | ||
- | === Power Tools === | ||
- | === Hand Tools === | ||
- | TBA |
- causes/woodworking
