Next revision | Previous revision Next revision Both sides next revision | ||
causes:woodworking [2020/04/11 12:01] 127.0.0.1 external edit |
causes:woodworking [2020/08/13 23:59] devians |
+ | {{:causes:woodshop-room.jpg?direct|The woodshop room as of 02/02/2019}} | ||
- | The Woodworking Cause is lead by Joshua Hogendorn, and receives quite a lot of help from Ian Roving. We're aiming to provide a shop that can cater for construction needs through to fine cabinetry and carving. | + | |**Location** | The woodworking cause is located in the big shed, in the large room on the eastern side of the building. | |
+ | |**Cause Leader** | Joshua Hogendorn | | ||
+ | |**Communications** | [[https://forum.hsbne.org/c/cause-effect/woodworking|Forum Category]] \\ [[https://discord.gg/gz8HnQJ|Discord Chat]] \\ [[https://trello.com/invite/b/xmODU9ax/e44742719bbd040c69a17dbfd8c9653f/woodshop|Trello Task Tracking]] | | ||
- | You can [[causes:woodworking:operatingpolicy|view our Operating Policy here on the Wiki]]. | + | </WRAP> |
Line 20: | Line 23: | ||
- | The Woodshop provides: | + | ^ Category ^ Name/Type/Spec/Grade ^ Used By ^ Available for use ^ Minimum Stocked ^ Maximum Stocked |
- | You can [[causes:woodworking:suppliers|See a list of companies to buy supplies at here]]. | + | | Blades | Scrollsaw 125mm 14TPI | Scrollsaw | 10 | 5 | 10 | |
- | + | | Blades | [[https://www.bunnings.com.au/craftright-10-piece-jigsaw-blade-set_p6320394|Jigsaw variety pack]] | Jigsaws | 1 | 2 | 5 | | |
- | ==== Shop Contents ==== | + | | Fasteners | Robertson 16mm | General Purpose | 1 Pack | 2 Packs | 10 Packs | |
- | === Power Tools === | ||
- | === Hand Tools === | ||
- | TBA |
- causes/woodworking
