causes:woodworking [2020/04/14 14:41] nogthree Adding top section. |
causes:woodworking [2020/08/14 00:18] devians |
{{:causes:woodshop-room.jpg?direct|The woodshop room as of 02/02/2019}} | {{:causes:woodshop-room.jpg?direct|The woodshop room as of 02/02/2019}} | ||
- | <panel> | + | <WRAP> |
- | **Location:** The woodworking cause os located in the big shed, in the large room on the eastern side of the building.\\ | + | |
- | **Cause Leader:**Joshua (devians) Hogendoorn \\ | + | |**Location** | The woodworking cause is located in the big shed, in the large room on the eastern side of the building. | |
- | **Objective:** The Woodworking Cause is lead by Joshua Hogendorn, and receives quite a lot of help from Ian Roving. We're aiming to provide a shop that can cater for construction needs through to fine cabinetry and carving.\\ | + | |**Cause Leader** | Joshua Hogendorn | |
- | **Members:** See [[https://portal.hsbne.org/cause/list/|Current List]]\\ | + | |**Objective** | We're aiming to provide a shop that can cater for construction needs through to fine cabinetry and carving. | |
- | **Communications:** [[https://forum.hsbne.org/c/cause-effect/woodworking|Forums]] and #woodchop in [[https://discord.gg/avtkH5t|Discord Chat]].\\ | + | |**Members** | [[https://portal.hsbne.org/cause/list/|Portal Cause Membership]] | |
- | **Operating Policy:** [[causes:woodworking:operatingpolicy| Operating Policy]]\\ | + | |**Communications** | [[https://forum.hsbne.org/c/cause-effect/woodworking|Forum Category]] \\ [[https://discord.gg/gz8HnQJ|Discord Chat]] \\ [[https://trello.com/invite/b/xmODU9ax/e44742719bbd040c69a17dbfd8c9653f/woodshop|Trello Task Tracking]] | |
- | </panel> | + | |**Operating Policy** | [[causes:woodworking:operatingpolicy| Operating Policy]] | |
Line 20: | Line 23: | ||
- | The Woodshop provides: | + | ^ Category ^ Name/Type/Spec/Grade ^ Used By ^ Available for use ^ Minimum Stocked ^ Maximum Stocked |
- | You can [[causes:woodworking:suppliers|See a list of companies to buy supplies at here]]. | + | | Blades | Scrollsaw 125mm 14TPI | Scrollsaw | 10 | 5 | 10 | |
- | + | | Blades | [[https://www.bunnings.com.au/craftright-10-piece-jigsaw-blade-set_p6320394|Jigsaw variety pack]] | Jigsaws | 1 | 2 | 5 | | |
- | ==== Shop Contents ==== | + | | Carbide | 07.0.020 10pc Carbide 13.8x13.8x2.5 mm | A3-31 | 0 | 10 | 10 | |
- | === Power Tools === | ||
- | === Hand Tools === | ||
- | TBA |
- causes/woodworking
