causes:woodworking [2020/08/13 23:59] devians |
causes:woodworking [2020/10/11 10:58] ale [Woodworking Cause] |
<WRAP> | <WRAP> | ||
|**Location** | The woodworking cause is located in the big shed, in the large room on the eastern side of the building. | | |**Location** | The woodworking cause is located in the big shed, in the large room on the eastern side of the building. | | ||
- | |**Cause Leader** | Joshua Hogendorn | | + | |**Cause Leader** | Ale Moré | |
|**Objective** | We're aiming to provide a shop that can cater for construction needs through to fine cabinetry and carving. | | |**Objective** | We're aiming to provide a shop that can cater for construction needs through to fine cabinetry and carving. | | ||
Line 34: | Line 34: | ||
- | ^ Category ^ Name/Type/Spec/Grade ^ Used By ^ Available for use ^ Minimum Stocked ^ Maximum Stocked | + | ^ Category ^ Name/Type/Spec/Grade ^ Used By ^ Available for use ^ Minimum Stocked ^ Maximum Stocked ^ |
| Sandpaper | Belt 150x1220mm @P120 | Disc&Belt Sander | 1 | 5 | 20 | | | Sandpaper | Belt 150x1220mm @P120 | Disc&Belt Sander | 1 | 5 | 20 | | ||
| Sandpaper | Disc 305mm @P120 | Disc&Belt Sander, 12" Disc Sander | 2 | 10 | 40 | | | Sandpaper | Disc 305mm @P120 | Disc&Belt Sander, 12" Disc Sander | 2 | 10 | 40 | | ||
Line 53: | Line 53: | ||
| Blades | Scrollsaw 125mm 14TPI | Scrollsaw | 10 | 5 | 10 | | | Blades | Scrollsaw 125mm 14TPI | Scrollsaw | 10 | 5 | 10 | | ||
| Blades | [[https://www.bunnings.com.au/craftright-10-piece-jigsaw-blade-set_p6320394|Jigsaw variety pack]] | Jigsaws | 1 | 2 | 5 | | | Blades | [[https://www.bunnings.com.au/craftright-10-piece-jigsaw-blade-set_p6320394|Jigsaw variety pack]] | Jigsaws | 1 | 2 | 5 | | ||
| Fasteners | Robertson 16mm | General Purpose | 1 Pack | 2 Packs | 10 Packs | | | Fasteners | Robertson 16mm | General Purpose | 1 Pack | 2 Packs | 10 Packs | | ||
| Fasteners | Robertson 22mm | General Purpose | 1 Pack | 2 Packs | 10 Packs | | | Fasteners | Robertson 22mm | General Purpose | 1 Pack | 2 Packs | 10 Packs | |
- causes/woodworking
