causes:woodworking [2020/08/11 19:59] devians |
<WRAP> | <WRAP> | ||
|**Location** | The woodworking cause is located in the big shed, in the large room on the eastern side of the building. | | |**Location** | The woodworking cause is located in the big shed, in the large room on the eastern side of the building. | | ||
- | |**Cause Leader** | Joshua Hogendorn | | + | |**Cause Leader** | Ale Moré | |
|**Objective** | We're aiming to provide a shop that can cater for construction needs through to fine cabinetry and carving. | | |**Objective** | We're aiming to provide a shop that can cater for construction needs through to fine cabinetry and carving. | | ||
- | |**Communications** | [[https://forum.hsbne.org/c/cause-effect/woodworking|Forum Category]] \\ [[https://discord.gg/gz8HnQJ|Discord Chat]] \\ [[https://trello.com/invite/b/xmODU9ax/e44742719bbd040c69a17dbfd8c9653f/woodshop|Trello Task Tracking]] | | + | |**Communications** | [[https://forum.hsbne.org/c/cause-effect/woodworking|Forum Category]] \\ [[https://chat.hsbne.org/|Discord Chat]] \\ [[https://trello.com/invite/b/xmODU9ax/e44742719bbd040c69a17dbfd8c9653f/woodshop|Trello Task Tracking]] | |
|**Operating Policy** | [[causes:woodworking:operatingpolicy| Operating Policy]] | | |**Operating Policy** | [[causes:woodworking:operatingpolicy| Operating Policy]] | | ||
- | You can [[causes:woodworking:suppliers|See a list of companies to buy supplies at here]]. | ||
Line 25: | Line 23: | ||
Line 32: | Line 34: | ||
- | ^ Category ^ Name/Type/Spec/Grade ^ Used By ^ Available for use ^ Minimum Stocked ^ Maximum Stocked | + | ^ Category ^ Name/Type/Spec/Grade ^ Used By ^ Available for use ^ Minimum Stocked ^ Maximum Stocked ^ |
| Sandpaper | Belt 150x1220mm @P120 | Disc&Belt Sander | 1 | 5 | 20 | | | Sandpaper | Belt 150x1220mm @P120 | Disc&Belt Sander | 1 | 5 | 20 | | ||
| Sandpaper | Disc 305mm @P120 | Disc&Belt Sander, 12" Disc Sander | 2 | 10 | 40 | | | Sandpaper | Disc 305mm @P120 | Disc&Belt Sander, 12" Disc Sander | 2 | 10 | 40 | | ||
Line 51: | Line 53: | ||
| Blades | Scrollsaw 125mm 14TPI | Scrollsaw | 10 | 5 | 10 | | | Blades | Scrollsaw 125mm 14TPI | Scrollsaw | 10 | 5 | 10 | | ||
| Blades | [[https://www.bunnings.com.au/craftright-10-piece-jigsaw-blade-set_p6320394|Jigsaw variety pack]] | Jigsaws | 1 | 2 | 5 | | | Blades | [[https://www.bunnings.com.au/craftright-10-piece-jigsaw-blade-set_p6320394|Jigsaw variety pack]] | Jigsaws | 1 | 2 | 5 | | ||
| Fasteners | Robertson 16mm | General Purpose | 1 Pack | 2 Packs | 10 Packs | | | Fasteners | Robertson 16mm | General Purpose | 1 Pack | 2 Packs | 10 Packs | | ||
| Fasteners | Robertson 22mm | General Purpose | 1 Pack | 2 Packs | 10 Packs | | | Fasteners | Robertson 22mm | General Purpose | 1 Pack | 2 Packs | 10 Packs | | ||
Line 87: | Line 90: | ||
| General | [[https://www.carbatec.com.au/149pce-knob-jig-pack-1-4|Jig Kit]] | Shop Maintenance | - | - | - | | | General | [[https://www.carbatec.com.au/149pce-knob-jig-pack-1-4|Jig Kit]] | Shop Maintenance | - | - | - | | ||
| General | [[https://gregmach.com/product/100x-roll-poly-dust-bags-500-x-1120mm-suit-dc1200de1200de1900/|Dust Bags]] | Shop Infrastructure | - | - | - | | | General | [[https://gregmach.com/product/100x-roll-poly-dust-bags-500-x-1120mm-suit-dc1200de1200de1900/|Dust Bags]] | Shop Infrastructure | - | - | - | | ||
- causes/woodworking.1597139940
