causes:woodworking [2018/03/05 14:43] |
Line 16: | Line 23: | ||
- | ==== Shop Contents ==== | + | | Sandpaper | Roll 79mm @P240 | Drum Sander | - | 5m | 50m | |
+ | | Sandpaper | Roll 93mm @P120 | Hand and Powertool Sanding | - | 5m | 50m | | ||
+ | | Blades | Bandsaw 12mm 06TPI | N4400 | 1 | 2 | 2 | | ||
+ | | Blades | Bandsaw 25mm 04TPI | N4400 | 1 | 2 | 2 | | ||
+ | | Blades | Bandsaw 06mm 14TPI | BP-250 | 1 | 2 | 2 | | ||
+ | | Blades | Bandsaw 03mm 18TPI | BP-250 | 1 | 2 | 2 | | ||
+ | | Blades | Scrollsaw 125mm 14TPI | Scrollsaw | 10 | 5 | 10 | | ||
- | * N4400 Bandsaw | ||
- | * H&F Mini Bandsaw | ||
- | * Radial Arm Saw | ||
- | * Disc Sander | ||
- | * Scrollsaw | ||
- | * Lathe | ||
- | === Power Tools === | ||
- | TBA | ||
- | === Hand Tools === | ||
- | TBA |
- causes/woodworking
