causes:woodworking [2018/12/01 14:01] |
causes:woodworking [2020/08/08 17:04] devians |
+ | {{:causes:woodshop-room.jpg?direct|The woodshop room as of 02/02/2019}} | ||
+ | |**Cause Leader** | Joshua Hogendorn | | ||
+ | |**Communications** | [[https://forum.hsbne.org/c/cause-effect/woodworking|Forums]] \\ [[https://discord.gg/gz8HnQJ|Discord Chat]] | | ||
- | You can [[causes:woodworking:operatingpolicy|view our Operating Policy here on the Wiki]] | + | You can [[causes:woodworking:suppliers|See a list of companies to buy supplies at here]]. |
Line 21: | Line 28: | ||
- | The Woodshop provides: | + | ^ Category ^ Name/Type/Spec/Grade ^ Used By ^ Available for use ^ Minimum Stocked ^ Maximum Stocked |
- | + | <nspages tools:woodshop -exclude:home -usePictures -h1 -textNS="" -textPages="" -subns -pagesInNs -defaultPicture="{{:wiki:logo.png}}" -naturalOrder> | |
- | * PS-12 Sliding Table Saw | + | |
- | * N4400 Bandsaw | + | |
- | * H&F Mini Bandsaw | + | |
- | * A3-31 Jointer/Planer Thicknesser | + | |
- | * Hitachi Drop/Mitre Saw | + | |
- | * Radial Arm Saw | + | |
- | * Disc Sander | + | |
- | * Scrollsaw | + | |
- | * Lathe | + | |
=== Power Tools === | === Power Tools === | ||
- | TBA | + | <nspages tools:woodshop:handpowertools -exclude:home -usePictures -h1 -textNS="" -textPages="" -subns -pagesInNs -defaultPicture="{{:wiki:logo.png}}" -naturalOrder> |
=== Hand Tools === | === Hand Tools === | ||
- | TBA | + | <nspages tools:woodshop:handtools -exclude:home -usePictures -h1 -textNS="" -textPages="" -subns -pagesInNs -defaultPicture="{{:wiki:logo.png}}" -naturalOrder> |
- causes/woodworking
