causes:woodworking [2020/01/18 12:30] |
causes:woodworking [2020/10/11 10:58] ale [Woodworking Cause] |
+ | |**Communications** | [[https://forum.hsbne.org/c/cause-effect/woodworking|Forum Category]] \\ [[https://discord.gg/gz8HnQJ|Discord Chat]] \\ [[https://trello.com/invite/b/xmODU9ax/e44742719bbd040c69a17dbfd8c9653f/woodshop|Trello Task Tracking]] | | ||
- | You can [[causes:woodworking:operatingpolicy|view our Operating Policy here on the Wiki]]. | + | |
Line 22: | Line 23: | ||
- | * [[/tools/woodshop/tablesaws|PS-12 Sliding Table Saw]] | ||
- | * N4400 Bandsaw | ||
- | * H&F Mini Bandsaw | ||
- | * [[tools:woodshop:thicknesserplaner|A3-31 Jointer/Planer Thicknesser]] | ||
- | * [[tools:woodshop:dropsaw|Hitachi Drop/Mitre Saw]] | ||
- | * Radial Arm Saw | ||
- | * [[tools:woodshop:discsander|Disc Sander]] | ||
- | * Scrollsaw | ||
- | * Lathe | ||
- | === Power Tools === | ||
- | TBA | ||
- | === Hand Tools === | ||
- | TBA |
- causes/woodworking
