Next revision
Last revision Both sides next revision
causes:woodworking [2020/08/14 00:18]
causes:woodworking [2020/10/11 10:58]
ale [Woodworking Cause]
Line 1: Line 1:
 ====== Woodworking Cause ====== ====== Woodworking Cause ======
-{{:​causes:​woodshop-room.jpg?​direct|The woodshop room as of 02/​02/​2019}}+{{ :​causes:​woodshop-room.jpg?​direct&600|The woodshop room as of 02/​02/​2019}}
 <​WRAP>​ <​WRAP>​
 |**Location** ​        | The woodworking cause is located in the big shed, in the large room on the eastern side of the building. | |**Location** ​        | The woodworking cause is located in the big shed, in the large room on the eastern side of the building. |
-|**Cause Leader** ​    ​| ​Joshua Hogendorn ​|+|**Cause Leader** ​    ​| ​Ale MorĂ© |
 |**Objective** ​       | We're aiming to provide a shop that can cater for construction needs through to fine cabinetry and carving. | |**Objective** ​       | We're aiming to provide a shop that can cater for construction needs through to fine cabinetry and carving. |
 |**Members** ​         | [[https://​portal.hsbne.org/​cause/​list/​|Portal Cause Membership]] | |**Members** ​         | [[https://​portal.hsbne.org/​cause/​list/​|Portal Cause Membership]] |
Line 34: Line 34:
 ==== Consumables ==== ==== Consumables ====
-^ Category ^ Name/​Type/​Spec/​Grade ^ Used By ^ Available for use ^ Minimum Stocked ^ Maximum Stocked+^ Category ^ Name/​Type/​Spec/​Grade ^ Used By ^ Available for use ^ Minimum Stocked ^ Maximum Stocked ​^
 | Sandpaper | Belt 150x1220mm @P120 | Disc&​Belt Sander | 1 | 5 | 20 | | Sandpaper | Belt 150x1220mm @P120 | Disc&​Belt Sander | 1 | 5 | 20 |
 | Sandpaper | Disc 305mm @P120 | Disc&​Belt Sander, 12" Disc Sander | 2 | 10 | 40 | | Sandpaper | Disc 305mm @P120 | Disc&​Belt Sander, 12" Disc Sander | 2 | 10 | 40 |
  • causes/woodworking
  • Last modified: 2 years ago
  • by devians
