howto:bins [2020/09/19 01:07] jabelone |
howto:bins [2020/11/17 17:30] eris [Outside Bins] |
====== Bins and Waste ====== | ====== Bins and Waste ====== | ||
==== Bin Liners ==== | ==== Bin Liners ==== | ||
- | Bin liners are located either on top of the kitchen fridge. If you come across a bin that is full, you should empty it and put in new bin liner. | + | Bin liners are located either on top of the kitchen fridge. If you come across a bin that is full, you should empty it into an outside skip and put in new bin liner. |
==== General Waste Bins ==== | ==== General Waste Bins ==== | ||
Line 11: | Line 11: | ||
We have a designated recycling bin in the kitchen area, and a larger recycling skip outside. All recyclable materials (such as cardboard, hard plastics and paper) should be recycled. Take note that take away food packaging is generally not recyclable unless it's clean and doesn't have a waxy coating. | We have a designated recycling bin in the kitchen area, and a larger recycling skip outside. All recyclable materials (such as cardboard, hard plastics and paper) should be recycled. Take note that take away food packaging is generally not recyclable unless it's clean and doesn't have a waxy coating. | ||
- | ==== Can Recycling ==== | + | ==== Can & Bottle Recycling ==== |
- | We encourage members to recycle all drinking cans, both from our on site vending machines and any that are bought on site. There is a yellow recycling bin with a can sized hole on the top near the kitchen area for this purpose. When this bin is full, it should be emptied into the bigger can recycling skip outside that is emptied regularly by the scouts. | + | We encourage members to recycle all drinking cans and redeemable bottles, both from our on site vending machines and any that are bought on site. There is a yellow recycling bin with a can sized hole on the top near the kitchen area for this purpose. When this bin is full, it should be emptied into the bigger can recycling skip outside that is emptied regularly by the scouts. |
We get money back from each can collected thanks to the QLD government's container recycling scheme, so make sure to recycle! | We get money back from each can collected thanks to the QLD government's container recycling scheme, so make sure to recycle! | ||
==== E-Waste Recycling ==== | ==== E-Waste Recycling ==== | ||
- | We have an on site E-Waste recycling bin courtesy of [citation needed]. You can use this bin to recycle non-commercial quantities of electronics such as TV screens, printers, computers, etc. Please do not leave anything outside or on top of this bin. If it's full, let the executive know and try again another day. | + | We have an on site E-Waste recycling bin courtesy of Substation 33. You can use this bin to recycle non-commercial quantities of electronics such as TV screens, printers, computers, etc. Please do not leave anything outside or on top of this bin. If it's full, let the executive know and try again another day. Do not recycle bare batteries here as it is a fire hazard. Take them to Aldi. Contained batteries such as drill batteries and laptops are acceptable. |
===== Outside Bins ===== | ===== Outside Bins ===== | ||
All of our inside bins need to be regularly emptied into our large skip bins outside. We have a few around, and these locations are explained on the map below. | All of our inside bins need to be regularly emptied into our large skip bins outside. We have a few around, and these locations are explained on the map below. | ||
- | {{:howto:hsbne-lease-map-bins.png?800|}} | + | {{{{{:howto:hsbne_bin_map_1_.jpg?400|}}} |
- howto/bins
- by eris
