Both sides previous revision
howto:upmini [2020/01/18 15:50] |
howto:upmini [2020/01/18 16:40] |
====== How to use the UP Mini ====== | ====== Use the UP Mini ====== |
| In order to use the UP Mini there are a few things you'll need to do. |
| - Check Printer Filament |
| - Take a look at the printer filament spool and ensure there's enough filament on the roll for your print. |
| - A good rule of thumb is for every square CM of your print there should be 15CM on the spool. |
| - Initialise Printer |
| - On the attached PC, run the 'UP 2.18' software. <WRAP center round info 60%>The Up Studio software isn't working with this printer anymore.</WRAP> |
| - On the Main Menu click 3D Print and then Initialize. |
| - Insert Bed |
| - Check the printer has a bed inserted, if not find a spare perfboard which should be with the printer. |
| - Slide the perfboard into the slots on the 2 sides of the platform, using your hands to support the platform and pushing down and forward with your thumbs. |
| - Test extrusion. |
| - On the Main Menu click 3D Print and then Maintenance |
| - Hit "Extrude" button. |
| - The printhead will start to heat up, within 5 minutes the printhead temperature will reach 260 degrees then the printer will buzz and the print head starts to extrude. |
| - Watch the printer push the filament out, making sure it's not coming out sideways. If it is, report it to the #digifab chat. |
| - When it completes it will beep again, pull the filament out and it should be a nice smooth coil of filament. <WRAP center round important 60%>Do not reach up towards the nozzle, reach down towards the bed.</WRAP><WRAP center round info 60%>If it is bubbly or textured report this to #digifab chat.</WRAP><WRAP center round info 60%>If the filament doesn't come out at all, report this to #digifab chat.</WRAP> |
| - Set up Print |
| - Clean off Bed |
| Changing Filament |
