howto:upmini [2020/10/17 13:32] hsbnewiki |
howto:upmini [2020/10/17 13:45] hsbnewiki |
- Take a look at the printer filament spool and ensure there's enough filament on the roll for your print. | - Take a look at the printer filament spool and ensure there's enough filament on the roll for your print. | ||
- A good rule of thumb is for every square CM of your print there should be 15CM on the spool. | - A good rule of thumb is for every square CM of your print there should be 15CM on the spool. | ||
- Initialise Printer | - Initialise Printer | ||
- On the attached PC, run the 'UP 2.18' software. <callout type="info" icon="true">Make sure you have opened Up 2.18, the 'Up Studio' software currently does not work with this printer.</callout> | - On the attached PC, run the 'UP 2.18' software. <callout type="info" icon="true">Make sure you have opened Up 2.18, the 'Up Studio' software currently does not work with this printer.</callout> | ||
Line 20: | Line 21: | ||
- Clean off Bed | - Clean off Bed | ||
- | Changing Filament | + | ====== Changing Filament ====== |
+ | - Click New Spool. | ||
- howto/upmini
- by hsbnewiki
