howto:upmini [2020/04/11 12:01] 127.0.0.1 external edit |
howto:upmini [2020/10/17 14:24] (current) hsbnewiki |
- Take a look at the printer filament spool and ensure there's enough filament on the roll for your print. | - Take a look at the printer filament spool and ensure there's enough filament on the roll for your print. | ||
- A good rule of thumb is for every square CM of your print there should be 15CM on the spool. | - A good rule of thumb is for every square CM of your print there should be 15CM on the spool. | ||
- Initialise Printer | - Initialise Printer | ||
- | - On the attached PC, run the 'UP 2.18' software. <WRAP center round info 60%>The Up Studio software isn't working with this printer anymore.</WRAP> | + | - On the attached PC, run the 'UP 2.18' software. <callout type="info" icon="true">Make sure you have opened Up 2.18, the 'Up Studio' software currently does not work with this printer.</callout> |
- On the Main Menu click 3D Print and then Initialize. | - On the Main Menu click 3D Print and then Initialize. | ||
- Insert Bed | - Insert Bed | ||
Line 16: | Line 17: | ||
- The printhead will start to heat up, within 5 minutes the printhead temperature will reach 260 degrees then the printer will buzz and the print head starts to extrude. | - The printhead will start to heat up, within 5 minutes the printhead temperature will reach 260 degrees then the printer will buzz and the print head starts to extrude. | ||
- Watch the printer push the filament out, making sure it's not coming out sideways. If it is, report it to the #digifab chat. | - Watch the printer push the filament out, making sure it's not coming out sideways. If it is, report it to the #digifab chat. | ||
- | - When it completes it will beep again, pull the filament out and it should be a nice smooth coil of filament. <WRAP center round important 60%>Do not reach up towards the nozzle, reach down towards the bed.</WRAP><WRAP center round info 60%>If it is bubbly or textured report this to #digifab chat.</WRAP><WRAP center round info 60%>If the filament doesn't come out at all, report this to #digifab chat.</WRAP> | + | - When it completes it will beep again, pull the filament out and it should be a nice smooth coil of filament. <callout type="danger" icon="fa fa-warning">Do not reach up towards the nozzle, reach down towards the bed.</callout><callout type="info" icon="true">If the filament is bubbly or textured or doesn't come out at all, report this to #digifab chat.</callout> |
- Set up Print | - Set up Print | ||
- | - Clean off Bed | + | - Load the .STL file by clicking the Open icon or choosing File → Open. |
+ | - Place the item using the toolbar to move it on the X, Y or Z axis OR click the AutoPlacement button from the toolbar.<callout type="info">AutoPlacement is recommended for multiple files in one print job.</callout> | ||
+ | - If necessary, scale the item up or down using the top drop-down menu and Scale button. | ||
+ | - Click the Print icon. | ||
+ | - A pop-up window will confirm print settings. Adjust printing speed as desired. Click “Preferences” to change fill, resolution, etc. Click OK when done. | ||
+ | - The UP!ware sends the file to the printer by slicing it into layers. See the progression in the bottom left toolbar. | ||
+ | - When slicing is completed, the printer will beep and a pop up window will tell you the approximate time for your print job and how much plastic will be used. | ||
+ | - The nozzle will heat to the necessary temperature. When the nozzle is heated, the printer will beep one long beep. Then it will beep 3 short beeps in a row before beginning to print. | ||
+ | - The printer will beep 5 short beeps in a row upon completing the print job. | ||
+ | - Remove the black platform plate from the printer. | ||
+ | - Use appropriate tools (bench hook, spatula, gloves) to remove the print job. | ||
+ | - Clean off the bed using the spatula. | ||
- | Changing Filament | + | ====== Changing Filament ====== |
+ | - Click New Spool. | ||
- howto/upmini.1586570496
- by 127.0.0.1
