Last revision Both sides next revision
infrastructure:services:accesscontrol [2020/01/18 13:45]
infrastructure:services:accesscontrol [2020/04/11 12:01]
127.0.0.1 external edit
Line 1: Line 1:
 ===== Our Current System ===== ===== Our Current System =====
 Our current system uses ESP8266 based hardware for WiFi-enabled doors, interlocks and vending machine controls. ​ Our current system uses ESP8266 based hardware for WiFi-enabled doors, interlocks and vending machine controls. ​
Line 11: Line 12:
 === Interlocks === === Interlocks ===
 +{{:​infrastructure:​interlockoutside.jpg?​400|}}
 Interlocks contains a Sonoff TH10, a 240v 20A 2Pole NO contactor, a 3.3v RFID reader and a single 20mm threaded case WS2812b led on a custom PCB that is wired into a TRRS connector on the sonoff. Interlocks contains a Sonoff TH10, a 240v 20A 2Pole NO contactor, a 3.3v RFID reader and a single 20mm threaded case WS2812b led on a custom PCB that is wired into a TRRS connector on the sonoff.
 +PCB Project: https://​easyeda.com/​wodann/​Interlock_Buzzer-10cdd361c1e342e8851967c3ef5db927
 Wiring Diagram: ​ Wiring Diagram: ​
 {{ :​infrastructure:​interlock_v2_wiring_diagram.pdf |}} {{ :​infrastructure:​interlock_v2_wiring_diagram.pdf |}}
-=== Vending Machines ===+=== Drinks ​Vending Machines ===
 The vending machines run a USB powered ESP8266 board (Wemos D1 Mini) that triggers a drink dispense via a relay. The vending machines run a USB powered ESP8266 board (Wemos D1 Mini) that triggers a drink dispense via a relay.
 +PCB Project: https://​easyeda.com/​wodann/​Spacebucks-Drinks-D1
 +=== Magnetic Door Holders ===
 +{{:​infrastructure:​maglocks.jpg?​400|}}
 +Our magnetic door holders use a Sonoff SV with a commercial 24v magnetic door holder and a reed switch. The firmware turns on the relay output for 150 seconds after the reed switch closes.
 === Useful Info === === Useful Info ===
  • infrastructure/services/accesscontrol
  • Last modified: 3 years ago
  • by jabelone
