infrastructure:services:unifisnapshotgetter [2019/08/16 11:14] |
infrastructure:services:unifisnapshotgetter [2021/10/20 23:32] jabelone |
Line 2: | Line 2: | ||
This docker container will grab a configuration file with a list of cameras in it and grab a snapshot from a Ubiquiti NVR every x seconds. It then stores it in an output location that is publicly accessible at portal.hsbne.org/webcams/. These snapshots are used in the [[infrastructure:services:memberportal|member portal]] and the [[infrastructure:HomeAssistant|home assistant]] instance. | This docker container will grab a configuration file with a list of cameras in it and grab a snapshot from a Ubiquiti NVR every x seconds. It then stores it in an output location that is publicly accessible at portal.hsbne.org/webcams/. These snapshots are used in the [[infrastructure:services:memberportal|member portal]] and the [[infrastructure:HomeAssistant|home assistant]] instance. | ||
- | More information and documentation is available in the github repo [[https://github.com/HSBNE/UniFiVideoSnapshotGetter|here]]. | + | ===Useful Info=== |
**Author(s):** Jaimyn (@jabelone)\\ | **Author(s):** Jaimyn (@jabelone)\\ | ||
- | **Current Maintainer(s):** Jaimyn (@jabelone)\\ | + | **Current Maintainer(s):** No one :(\\ |
- | **Running On:** [[infrastructure:servers:porthack01|Porthack01]] | + | **Running On:** [[infrastructure:servers:porthack01|Porthack01]]\\ |
+ | **GitHub:** [[https://github.com/HSBNE/UniFiVideoSnapshotGetter|UniFi Video Snapshot Getter]] |
- infrastructure/services/unifisnapshotgetter
- by jabelone
