infrastructure:services:unifisnapshotgetter [2019/08/15 16:37] |
infrastructure:services:unifisnapshotgetter [2020/04/11 12:01] 127.0.0.1 external edit |
Line 2: | Line 2: | ||
This docker container will grab a configuration file with a list of cameras in it and grab a snapshot from a Ubiquiti NVR every x seconds. It then stores it in an output location that is publicly accessible at portal.hsbne.org/webcams/. These snapshots are used in the [[infrastructure:services:memberportal|member portal]] and the [[infrastructure:HomeAssistant|home assistant]] instance. | This docker container will grab a configuration file with a list of cameras in it and grab a snapshot from a Ubiquiti NVR every x seconds. It then stores it in an output location that is publicly accessible at portal.hsbne.org/webcams/. These snapshots are used in the [[infrastructure:services:memberportal|member portal]] and the [[infrastructure:HomeAssistant|home assistant]] instance. | ||
- | This was written by Jaimyn Mayer in python and runs in a docker container. More information and documentation is available in the github repo [[https://github.com/HSBNE/UniFiVideoSnapshotGetter|here]]. | + | ===Useful Info=== |
- | + | **Author(s):** Jaimyn (@jabelone)\\ | |
- | Current Maintainer(s): Jaimyn Mayer (@jabelone) | + | **Current Maintainer(s):** Jaimyn (@jabelone)\\ |
+ | **Running On:** [[infrastructure:servers:porthack01|Porthack01]]\\ | ||
+ | **GitHub:** [[https://github.com/HSBNE/UniFiVideoSnapshotGetter|UniFi Video Snapshot Getter]] |
- infrastructure/services/unifisnapshotgetter
- by jabelone
